[GRASS-dev] Re: regex problem for r.in.wms
Ivan Shmakov ivan at theory.asu.ru
Mon Mar 10 14:58:52 EDT 2008
>>>>> Hamish  <hamish_b at yahoo.com> writes:
 > Hi, re. r.in.wms XML paring code for layers with spaces in the name
 > given some text like this:
 > DATA="<Name>Foo Bar Baz</Name>"
 > echo "$DATA" | sed -e "s/<Name>\s*\(\w*\)/~\1~/g" -e "s/<\/Name>//g"
 > you get ~Foo~ Bar Baz
 > instead of ~Foo Bar Baz~
 > how to fix that regex?
	First of all, we expand `\w' into ``any letter or digit or the
	underscore character'' [1]:
echo "$DATA" \
    | sed -e "s/<Name>\s*\([[:alpha:][:digit:]_]*\)/~\1~/g" \
          -e "s/<\/Name>//g"
## => ~Foo~ Bar Baz
	Then, we add `[:space:]' to the []-set:
echo "$DATA" \
    | sed -e "s/<Name>\s*\([[:alpha:][:digit:][:space:]_]*\)/~\1~/g" \
          -e "s/<\/Name>//g"
## => ~Foo Bar Baz~
	Finally, I'd recommend to use single quotes for the Sed program,
	since it has no Shell substitutions contained within:
echo "$DATA" \
    | sed -e 's/<Name>\s*\([[:alpha:][:digit:][:space:]_]*\)/~\1~/g' \
          -e 's/<\/Name>//g'
## => ~Foo Bar Baz~
[1] GNU Sed manual (for GNU Sed 4.1.5.)
