[GRASS-dev] [GRASS GIS] #88: opt->guisection and opt->label for a
better GUI world
trac at osgeo.org
Tue Mar 11 08:02:48 EDT 2008
#88: opt->guisection and opt->label for a better GUI world
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
this was wish # 238 on the old gforge system. moving it here.
http://wald.intevation.org/tracker/index.php?func=detail&aid=238&group_id=21&atid=188
2006-11-18
> I have updated a few complicated modules to use opt->guisection for
nicer
> GUI menus using tabs.
> d.legend
> d.vect
> r.report
> r.watershed
> r.sunmask
> v.buffer
> v.label
> already done by Cedric:
> r.in.wms
> g.region
> to be done:
> (see below)
> Wierdness-
> order of tabs:
> the tab containing the first flag determines which tab comes first.
> the default tab "Options" should always be first.
> tcltk bug:
> guisections with a space in them cause a tcl error (quoting? list vs
string?)
> e.g. r.watershed, r.sunmask (I've used underscores)
> I also updated parser.c to use opt->label a little more. (if opt->label
> is used, it becomes the option's description, and the opt->description
> text becomes the tooltip.
> Suggestion- opt->description is long established, don't mess with it.
> change opt->label to opt->tooltip and reverse its meaning.
> Tooltips are good.
> Suggestion 2- move G_define_module(), G_define_flag(),
G_define_option(),
> and G_define_standard_option() out of parser.c. It's a 2,500 line long
> monster.
> back to guisection:
> The hierarchical rule of thumb is if it has more than 12 subordinates,
> split it into smaller groups. But it's not a hard rule, e.g. I think
> r.in.xyz is ok in a single tab.
> here are the modules with more than 12 options+flags. I have removed
> the ones already mentioned above.
> cd $GISBASE/docs/html/
> # ($1 -2) is to ignore --q,--v
> grep "<DT><b>" * | cut -f1 -d: | uniq -c | sort -n | \
> awk '{if($1 -2 > 12) print }' | sed -e 's/\.html$//'
[rerun 11 Mar 2006]
15 d.grid
15 d.path
15 d.vect.chart
15 g.remove
15 i.atcorr
15 r.terraflow
15 v.net.path
16 d.legend
16 d.nviz
16 r3.out.vtk
16 r.ros
17 g.proj
17 r.cost
17 r.in.xyz
17 r.out.vtk
17 r.report
17 v.distance
18 r.topmodel
19 r.in.bin
19 r.le.patch
19 r.slope.aspect
19 v.in.ascii
19 v.lrs.create
20 d.text.freetype
20 d.text
20 r3.gwflow
20 r.stats
20 r.sunmask
20 r.walk
20 r.watershed
20 v.transform
21 r.resamp.rst
21 r.spread
22 r.texture
22 v.in.ogr
23 r.sim.sediment
23 v.generalize
23 v.lrs.label
24 r.sun
24 v.edit
25 v.label
26 r.gwflow
26 r.in.wms
27 r.sim.water
27 v.vol.rst
28 d.vect.thematic
31 v.surf.rst
33 d.vect
36 g.region
old bug history: (reverse order)
Followup:
Message
Date: 2007-04-22 21:27
Sender: Hamish B
v.distance is done.
Hamish
Date: 2007-03-23 17:28
Sender: Hamish B
v.in.ascii is done.
Hamish
Date: 2006-11-27 17:10
Sender: Hamish B
d.vect.thematic has been done by Michael.
d.what.vect is a false positive.
This leaves these ones TODO:
15 g.remove
15 r.flow
15 r.terraflow
16 d.nviz
16 r.out.vtk
16 r3.out.vtk
16 r.ros
16 d.text.new
17 d.text.freetype
17 r.cost
17 v.distance
17 v.lrs.create
18 r.topmodel
19 r.le.patch
20 r.stats
20 r.walk
20 v.in.ogr
21 r.spread
21 v.in.ascii
21 v.lrs.label
Hamish
Hamish
Date: 2006-11-22 14:50
Sender: Hamish B
v.vol.rst
r.texture
r.resamp.rst
are done.
Hamish
Date: 2006-11-19 04:03
Sender: Hamish B
v.transform is done.
Hamish
Date: 2006-11-19 03:47
Sender: Hamish B
done for these:
r.sim.water
r.sim.sediment
r.slope.aspect
r.in.bin
r.sun
v.surf.rst
these remain:
> 15 d.what.vect
> 15 g.remove
> 15 r.flow
> 15 r.terraflow
> 16 d.nviz
> 16 d.text.new
> 16 r.out.vtk
> 16 r.ros
> 16 r3.out.vtk
> 16 v.transform
> 17 d.text.freetype
> 17 r.cost
> 17 v.distance
> 17 v.lrs.create
> 18 r.topmodel
> 19 r.le.patch
> 20 r.stats
> 20 r.walk
> 20 v.in.ogr
> 21 r.resamp.rst
> 21 r.spread
> 21 v.in.ascii
> 21 v.lrs.label
> 23 r.texture
> 26 v.vol.rst
> 28 d.vect.thematic
Ticket URL: <http://trac.osgeo.org/grass/ticket/88>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
