[GRASS-dev] [GRASS GIS] #91: ps.map doesn't remove .tmp files when
it is done
trac at osgeo.org
Tue Mar 11 08:13:20 EDT 2008
#91: ps.map doesn't remove .tmp files when it is done
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
this was bug # 492 in the old gforge system. moving it here.
http://wald.intevation.org/tracker/index.php?func=detail&aid=492&group_id=21&atid=204
Hamish
ps.map creates some .tmp files, e.g. when the 'text' or 'rectangle'
instructions are used but they aren't removed when the module finishes.
For scripted ps.map jobs / trial+error iterations you end up with hundreds
of tiny files in the .tmp dir until you exit the GRASS session.
They are human readable and useful for debugging, so it would be nice to
only remove them if the g.gisenv DEBUG level was below some threshold.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/91>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
