[GRASS-dev] [GRASS GIS] #89: d.legend: option to get info from stdin instead of raster
Wed Mar 12 01:33:05 EDT 2008
>  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
>      Type:  enhancement  |      Status:  new
>  Priority:  minor        |   Milestone:  6.4.0
> Component:  default      |     Version:  unspecified
>  Keywords:               |
>  this was code wish # 391 over on the old gforge tracker. moving it here.
>  http://wald.intevation.org/tracker/index.php?func=detail&aid=391&group_id=21&atid=188
>  Hamish
>  Hi,
>  It would be nice if d.legend could look for "map=-" and if so take legend
>  cat and color info from stdin. That way vector maps and custom legends
>  could be made without resorting to tricks like making a dummy raster file
>  to hold
>  that info.  [see v.colors addon script]
The basic idea is reasonable enough, but:
1. The map= option shouldn't be (ab)used for that purpose. There
should be separate options instead. Apart from anything else, you
either have to change map->gisprompt to allow something which isn't a
map (which means that you don't get the map browser in the GUI), or
you leave map->gisprompt alone but then can't use that feature from
the GUI.
2. Using stdin is generally a bad idea. It doesn't work with the GUI.
The module needs to copy the data to a temporary file so that d.save,
d.redraw etc work.
