R: R: R: [GRASS-dev] WinGRASS-6.3.0RC5 Self Installer
Marco Pasetti
marco.pasetti at alice.it
Wed Mar 12 16:32:14 EDT 2008
Hi Glynn,
>Please note that, if you provide binaries which are covered by the GPL, you
must provide the corresponding source code for download *from the same
place*. It isn't sufficient to point to the source on a different site.
>Alternatively, you can provide a written offer to supply the source code
upon request, but that means that you have to keep those exact versions of
the source code handy for the next 3 years (the website where you obtained
it may cease to provide it when a new version is released).
I think that this is a problem I should don't care, actually. I asked the
list if there were problems about that and I had the green light... If you
don't agree, I think you should discuss the matter with other persons, I
don't have the knowledge to neither reply nor discuss it.
>What's the problem with spaces? If any part of GRASS can't handle spaces in
filenames, that's a bug which should be fixed.
I would like to fix the problem too. Actually I spent some time on the
installer script to configure GRASS in order to let it work also in dirs
with spaces (in the first edition, in fact, installer used
%PROGRAMFILES%\GRASS-6.3.0 as standard install dir, that means, for english
versions of Windows, C:\Program Files\GRASS-6.3.0); but, after completing
the installer with success, I discovered that there are many things in GRASS
that definetely don't work because that "spaced" intallation directory: no
help pages, no NVIZ...
I think that forcing users to install GRASS in a "space free" dir is, at the
moment, the only solution to let us distribute winGRASS with a simple
"one-touch" installation procedure. BTW you can consider that if you (user)
have administrative limitations, you can ask your Administrator to let you
install GRASS in C:\GRASS... You're not installing Pacman ;-) ... And then
you can always store and access your data from GRASS in a usual C:\Documents
and settings\Glynn\Documents\Whatever You Want With Lots Of Spaces folder...
It works, I swear :-)
Marco
-----Messaggio originale-----
Da: Glynn Clements [mailto:glynn at gclements.plus.com]
Inviato: mercoledì 12 marzo 2008 20.34
A: Marco Pasetti
Cc: 'Michael Barton'; grass-dev at lists.osgeo.org
Oggetto: Re: R: R: [GRASS-dev] WinGRASS-6.3.0RC5 Self Installer
Marco Pasetti wrote:
> In the pure MS style, installer includes all: tcl/tk, sqlite,
> postgresql (the last only dll) built from source, and prebuilt msys
> from sourceforge project.
> Moreover, the installer procedure forces the user to install GRASS in
> a path without spaces, to let it wotk properly,
Also, some users may not be able to satisfy that requirement. The normal
location for installing software often has spaces in the pathname (e.g.
"C:\Program Files" on English language versions of Windows), as does the
user's data directory (e.g.
"C:\Documents and Setttings\<username>").
All users can create files in their data directory, while the "Program
Files" directory is normally writable by members of the "Power Users"
group. OTOH, creating a new directory outside of those two locations may not
be possible if the user isn't in the Administrators group.
