[GRASS-dev] Re: r.univar: allow multiple rasters to be processed
Ivan Shmakov
ivan at theory.asu.ru
Fri Mar 14 13:37:29 EDT 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>>>> Is there some fundamental reason why r.univar has separate cases
>>>> for CELL/FCELL/DCELL types, rather than just working in DCELL
>>>> throughout?
>>> I can't remember with any certainty why I did it that way; it's
>>> been like that since the first CVS checkin.
>> Please consider the following patch.
>> RASTER_MAP_TYPE map_type;
>> + void *all_values
>> + = ((! param.extended->answer) ? 0
>> + : (map_type == DCELL_TYPE) ? stats->dcell_array
>> + : (map_type == FCELL_TYPE) ? stats->fcell_array
>> + : stats->cell_array);
> map_type hasn't been initialised yet. There's no reason why it can't
> be initialised in the declaration, i.e.:
> RASTER_MAP_TYPE map_type = G_get_raster_map_type (fd);
> We have G_raster_size() for this:
> all_values is a void*, and arithmetic on a void* isn't permitted by
> ANSI C (gcc allows it as an extension).
> We have G_incr_void_ptr() for this, e.g..:
> memcpy(G_incr_void_ptr(all_values, stats->n * value_sz), ptr,
> value_sz);
> Or you can just make it a char* instead.
Yes, thanks.
I hope to test the corrected patch within a few days.
