[GRASS-dev] Re: [GRASS GIS] #81: scripts: "echo -n" not portable
trac at osgeo.org
Sat Mar 15 00:01:15 EDT 2008
Reporter: hamish | Owner: hamish
Type: defect | Status: assigned
Priority: blocker | Milestone: 6.3.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Comment (by hamish):
Glynn wrote:
> I wouldn't count on it; the shell may attempt to evaluate the ${...}
> part.
> I suspect that may be why it was output in pieces in the first place.
> Try:
> echo 'eval '"$3"'=${'"$1""[$2]}"
I glazed over last time I tried to follow that, not realizing that it is
just a straight concatenation of the series of 'echo -n' lines. So no less
safe than what is currently there.
Paul also suggested using GRASS's own $GISBASE/etc/echo which respects -n,
which could be clearer but doesn't help us ween ourselves off of
workaround apps.
I am currently leaning towards Glynn's suggestion as it requires a smaller
toolset.
I had guessed that in OSX 10.5 /bin/echo did not like -n but the bash
shell was ok with it (and so !/bin/bash'ing r.tileset apparently worked
without modification). Rereading William's comment in this bug report
suggests the opposite it true. Best to just get rid of the -n rather than
spend time trying to work out why..
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/81#comment:4>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
