[GRASS-dev] GRASS 6.3.0
Martin Landa
landa.martin at gmail.com
Mon Mar 17 18:54:44 EDT 2008
2008/3/15, Hamish <hamish_b at yahoo.com>:
> Martin Landa wrote:
> > we are a little bit late with releasing 6.3.0,
Hamish:
> no big hurry.
well, just comparing rc5-rc1 --- almost 5 months (to be honest,
postponed mainly because wxGUI backport). Anyway I would personally
prefer *smaller* release intervals (more releases in the result). Just
to illustrate
6.0.0 20050310
~ 1y5m
6.1.0 20060811
~ 2m
6.2.0 20061031
~ 1y5m
6.3.0 2008????
6.4.0 2008?
7.0.0 ? (development not started)
> > looking at [1,2] I don't see any (really) blocker issue (maybe vdigit
> > linking problem, but this can wait for 6.3.1 I guess).
Hamish:
> Before 6.3.0 I would like to finish making r.tileset "echo -n" portable
> (trac bug #81) and then backport r.in.wms fixes, and also see if we can
> fix the GIS.m off-by-one fill/boundary rendering (trac bug #72)
> http://trac.osgeo.org/grass/ticket/81
> http://trac.osgeo.org/grass/ticket/72
> As r.in.wms has been reported to work on Mac 10.5, I infer that the
> #!/bin/bash used by r.tileset makes it use bash's internal echo (which
> supports echo -n) instead of a system BSD /bin/echo which does not. (??)
> Even if that is so, it's probably a good idea to fix anyway. The eval
> within a function within another function and array quoting makes my head
> hurt, so for clarity's sake I am leaning towards going with Paul's
> suggestion of using GRASS's own $GISBASE/etc/echo there and keeping the
> -n, versus Glynn's patch which I find hard to review beyond trial & error
> tests which I can't properly do without OSX 10.5, which I don't have.
> Not having to resort to using our own echo.c is preferable, but for the
> pending 6.3.0 release this seems to me the less worrisome solution.
OK, I cannot judge it, anyway could be maybe fixed for 6.3.1 or 6.4.0.
> There are a lot of other script fixes not backported to 6.3.0, mostly
> bulk quoting of variables. I didn't backport them as I have not
> individually tested the changes and so don't guarantee they are no
> introduced typos. These will help with the spaces in pathnames problems,
> which are mostly a MS Windows phenomenon. I did not systematically quote
> everything, so it is almost certain that there will be more unquoted path
> and file names. These fixes might be nice to get out to MS Windows users
> in a 6.3.1 after more testing in SVN/trunk. Probably easier to cut a new
> 6_3_1 branch from the main grass6 line than to bother backporting things
> to 6.3.0's branch.
Hm, creating branch for 6.3.1 seems to be a bit complicated to me. I
would prefer releasing 6.3.0, creating branch for 6_4 (trunk for 7.x).
Releasebranch_6_3 used for 6.3.1 (after tagging 6.3.0) as usually.
> (unless a major bug is discovered and we want to release a quick 6.3.1)
> Is there a need for one last 6.3.0rc6 before release since all the new wx
> backport changes?
Maybe yes. I don't know maybe this kind of decisions should be done
through PSC or at least by release manager.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
