[GRASS-dev] [GRASS GIS] #99: r.resamp.interp fails for bicubic
and bilinear interpolation
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Mar 18 17:01:24 EDT 2008
On Mar 18, 2008, at 2:39 PM, GRASS GIS wrote:
> #99: r.resamp.interp fails for bicubic and bilinear interpolation
> Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: critical | Milestone: 6.3.0
> Component: default | Version: unspecified
> Keywords: |
> I just found out that r.resamp.interp fails for both bicubic and
> bilinear
> interpolation. It makes maps with all NAN values. I used the new
> NC data
> set and produced a set of random elevation points (raster and
> vector),
> then tried to use these in r.resamp.interp.
Michael - unless you have at least on point per cell NAN is actually
a correct result.
r.resamp.interp is for resampling a raster map not for interpolating
from randomly distributed points.
Eg this is the example from the book - you go from 30m resolution to
10m resolution -
let me know if that does not work (then we are in trouble because
this worked so we may have a bug introduced somewhere).
g.region rast=elevation -p
r.resamp.interp elev_ned_30m out=elev_ned10m_bil meth=bilinear
r.resamp.interp elev_ned_30m out=elev_ned10m_bic meth=bicubic
Helena
> The nearest neighbor routine
> worked, but the others did not. I tried the original raster point
> map and
> also tried one that I converted to a CELL map. Neither gave usable
> results. FWIW, I got the same result using r.bilinear.
> I'm having a very difficult time putting together a class on
> interpolation
> using GRASS today. v.surf.bspline does not work, 2 of the 3
> methods in
> r.resamp.interp do not work. r.bilinear does not work. Pretty bad
> press.
> Michael
> Ticket URL: <http://trac.osgeo.org/grass/ticket/99>
> GRASS GIS <http://grass.osgeo.org>
> GRASS Geographic Information System (GRASS GIS) - http://
> grass.osgeo.org/_______________________________________________
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
