[GRASS-dev] Re: [GRASS GIS] #97: r.random fails with bus error on
Mac OS X 10.5
trac at osgeo.org
Wed Mar 19 00:56:43 EDT 2008
#97: r.random fails with bus error on Mac OS X 10.5
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.3.0
Component: default | Version: unspecified
Resolution: | Keywords: r.random Mac
Comment (by glynn):
Replying to [comment:1 kyngchaos]:
> verified bus error on Leopard and OK on tiger, SVN 3/8. Here is the
thread trace from the crashlog:
> Thread 0 Crashed:
> 0 r.random 0x000021a7 set_max + 103
> 1 r.random 0x00002498 get_stats + 686
I don't know if it's related to the crash, but the way that the RASTER_PTR
union is used in get_stats violates ANSI C aliasing rules. Specifically,
the code stores a pointer in data.v but then uses data.[cfd]. Because
those fields have different types, the compiler is entitled to treat the
fields as distinct, even though they overlap. E.g. if it has a copy of
data.c in a register, and you modify data.v, references to data.c may
still use the value stored in the register.
As for the crash, we really need at least a proper backtrace with argument
values, and ideally the values of any relevant variables.
Ticket URL: <http://trac.osgeo.org/grass/ticket/97#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
