[GRASS-dev] g.mapsets revision 30712
Tue Mar 25 06:23:16 EDT 2008
	r30712 | martinl | 2008-03-24 11:19:11 +0000 (Mon, 24 Mar 2008) | 2 lines
	g.mapsets: (cosmetics) message cleaning, some minor changes in manual, tcl/tk-related code removed
Presumably g.mapsets.tcl should be removed, now that it is no longer
used.
Also, I've removed the code which was commented-out.
In general, code should be removed altogether rather than being
disabled (and #if 0/#endif is preferable to commenting). If someone
wants to resurrect the old code, they can get and old version from
SVN.
The only reason to leave unused code in is if it needs to be disabled
temporarily, e.g. if it doesn't work but you can't figure out how to
fix it.
