[GRASS-dev] WinGRASS-6.3.0RC6: First Impressions
Marco Pasetti marco.pasetti at alice.it
Wed Mar 26 16:32:52 EDT 2008
I just built RC6; first impressions:
1) make procedure fails creating symbolic links d.paint.labels, r.cats and
p.out.vrml; as temporary solution I fixed the problem manually creating
symbolic links after make procedure; it seems that MinGW needs the full path
for both target and link name...
2) About GRASS (from Help menu) works now
3) I opened some exixsting projects, applied some commands and used NVIZ;
all seems to works fine; good job folks! ;-)
More testing is needed, but at the moment I don't have enough time :-(
I'm planning self installer release for tomorrow (with new zipped MSYS
environment, readme files and guide updates)
4) I started the new python GUI: the first screen is OK (very beautiful...
but the fonts seem to be a little bit too small for me... probably I need
new glasses :-D), but loading a mapset it returns an error and exits; the
first time it reported and error with a *classic* windows message box, then,
when I restarted it, it displayed the following *only MSYS* message:
Marco at NOTEBOOKMARCO /usr/local/bin
$ grass63 -wxpython
Cleaning up temporary files.....
Starting GRASS ...
  File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/gis_set.py", line 31, in
<module>
    from gui_modules import globalvar
  File "C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\globalvar.py",
line 27, in <module>
    import wx
  File
"C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\__init__.py",
line 45, in <module>
    from wx._core import *
  File
"C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line
14526, in <module>
    from _windows import *
ValueError: bad marshal data
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
That's all at the moment.
Marco
