R: [GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
marco.pasetti at alice.it
Thu Mar 27 05:29:06 EDT 2008
Markus,
actually... NO!
I read the *alert* in the *error* lines, but I thought that it was a part of wxpython install, and that, in some way, I didn't found it because of *internal* errors! all that because python-NumPy is not included in python GUI requirements
so, I'll install it and retry ;-)
please patch http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README <http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README> and add info about it.
Thanks
Marco
Da: neteler.osgeo at gmail.com per conto di Markus Neteler
Inviato: gio 27/03/2008 10.16
A: marco.pasetti at alice.it
Oggetto: Re: [GRASS-dev] WinGRASS-6.3.0RC6 & Python GUI
Ciao Marco,
do you actually have python-NumPy installed?
That's needed...
ciao
markus
On Thu, Mar 27, 2008 at 10:10 AM, <marco.pasetti at alice.it> wrote:
> Hi all,
> I reinstalled Python (2.5.2) + Python Extensions for Windows (Build 210 -
> py2.5) + WxPython (2.8.7.1 - unicode - py25) but I still have the same
> errror (follows):
> http://www.webalice.it/marco.pasetti/temp/grass_bugs/bug002.png
> Then, after pressing ok button, reports as follows in MSYS console:
> Marco at NOTEBOOKMARCO /usr/local/bin
> $ grass63 -wxpython
> Cleaning up temporary files.....
> Starting GRASS ...
> WARNING: Attention!
> WARNING: Locking is not supported on Windows!
> GRASS GUI should be wxpython
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS 6.3.0RC6 (2008)
> GRASS homepage: http://grass.osgeo.org/
> This version running thru: Bourne Shell (/bin/sh)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> GRASS 6.3.0RC6 (SIT-Lombardia):C:/MSYS/local/bin >
> profile.py:
> This module requires the NumPy module,
> which could not be imported. It probably is not installed
> (it's not part of the standard Python distribution). See the
> Numeric Python site (http://numpy.scipy.org <http://numpy.scipy.org/> ) for information on
> downloading source or binaries.
> Traceback (most recent call last):
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1358, in
> <module>
> sys.exit(main())
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1351, in
> main
> app = GMApp(workspaceFile)
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1273, in
> __init__
> wx.App.__init__(self, False)
> File
> "C:\DevTools\Python\Lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line
> 7836, in __init__
> self._BootstrapApp()
> File
> 7433, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1289, in
> OnInit
> workspace = self.workspaceFile)
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 158, in
> __init__
> self.NewDisplay(show=False)
> File "C:/MSYS/local/grass-6.3.0RC6/etc/wxpython/wxgui.py", line 1025, in
> NewDisplay
> auimgr=self._auimgr, showMapDisplay=show)
> File
> "C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\wxgui_utils.py", line
> 76, in __init__
> self.Map = render.Map() # instance of render.Map to be associated
> with display
> File "C:\MSYS\local\grass-6.3.0RC6\etc\wxpython\gui_modules\render.py",
> line 210, in __init__
> self.InitRegion()
> line 244, in InitRegion
> self.SetRegion()
> line 462, in SetRegion
> self.region = self.__adjustRegion()
> line 296, in __adjustRegion
> mapwidth = abs(self.region["e"] - self.region["w"])
> KeyError: 'e'
> Martin, I really don't know why it works for you and not for me! There's
> something frustrating in that, because you followed the guide I wrote... and
> that I, obviously, followed too!
> Marco
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080327/0b7943b9/attachment.html
