[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm
garbled when NVIZ is not top window
trac at osgeo.org
Thu Mar 27 08:10:40 EDT 2008
#104: saving display to tiff or ppm garbled when NVIZ is not top window
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: NVIZ openGL
Comment (by glynn):
Replying to [comment:4 dylan]:
> Some updates (2008-03-26 SVN) & "nvidia" driver with DRI/GLX enabled.
> 1. export to full-res PPM, no error messages but results in black image.
> Creating PBuffer Using GLX 1.3
I think I've fixed this; at least, it works on my system.
The main change was to create a new context rather than using the existing
context.
I've also changed the glXChooseFBConfig() call so that it only reports
FBConfigs which are likely to actually work (e.g. those which are
compatible with pBuffers and have a depth buffer).
Ticket URL: <http://trac.osgeo.org/grass/ticket/104#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
