[GRASS-dev] Current state of wxPython GUI
benjamin.ducke at ufg.uni-kiel.de
Thu Mar 27 12:47:11 EDT 2008
>> IndexError: list index out of range
> should be also fixed in trunk now
OK, that works now.
>> 2. The GRASS init shell script now dumps this message twice to the
console:
>> "To run a command as administrator (user "root"), use "sudo <command>".
>> See "man sudo_root" for details."
>> I guess it attempts to run something with su privileges?
> OK, I assume this is well-known 'sudo' behaviour issue on Ubuntu...
I am only getting second thoughts that this means some important
commands are not being run upon start-up on Ubuntu.
Do you know which commands might cause these messages so I can look
into it?
Best,
Benjamin
> Martin
