R: R: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
Marco Pasetti marco.pasetti at alice.it
Thu Mar 27 21:05:33 EDT 2008
Hi Moritz,
>personally, I think the information about the GDAL, proj, etc are minor
compared to the info about postgresql.
Maybe you could just add a ** with a note "packages containing libraries and
binaries, all others only contain library files", or something similar.
Please, check if it works for you now. It's late here, and my brain
continues to fail connections (brain ping errors!), so you'll probably need
to fix my english errors ;-)
Goodnight
Marco
-----Messaggio originale-----
Da: Moritz Lennert [mailto:mlennert at club.worldonline.be]
Inviato: giovedì 27 marzo 2008 23.23
A: Marco Pasetti
Cc: 'GRASS Developer Mailing List'
Oggetto: Re: R: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
On Thu, March 27, 2008 23:06, Marco Pasetti wrote:
> Hi Moritz,
>>Just one last remark: IIRC, for PostgreSQL you only provide the
>>libpg.dll,
> not the entire postgresql installation.
>>This should be mentioned. And what about sqlite ? Did you include the
> sqlite.exe ?
> For PostgreSQL I provide only libpq.dll, while for SQLite I provide
> *all the build*, that is also sqlite.exe.
> On the same way, should I notice also further info for Tcl/Tk (as for
> SQLite, I provide *all the build* of it)?
> But this would open a *pandora's box*, because on this way I should
> specify also what files I exactly provide from other stuffs (such as
> tiff, gdal,
> proj....)
> Opened to all suggestions ;-)
Moritz
> Marco
> Inviato: giovedì 27 marzo 2008 22.59
> A: Marco Pasetti
> Cc: GRASS Developer Mailing List
> Oggetto: Re: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
> On Thu, March 27, 2008 22:46, Marco Pasetti wrote:
>> Hi all,
>> Thanks for all the suggestions: I modified the document, and finally
>> it sounds good for me:
>> http://www.webalice.it/marco.pasetti/temp/README.html
>> So, let's start the poll! ;-)
> libpg.dll, not the entire postgresql installation. This should be
> mentioned. And what about sqlite ? Did you include the sqlite.exe ?
> Moritz
>> Marco
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
