R: R: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
Fri Mar 28 07:31:27 EDT 2008
Marco Pasetti wrote:
> I succesfully built libjpeg, but during tests it reported errors, so I
> decided to remove it and then build TIFF without it; In wish list I meant to
> add jpeg and its support in tiff.
Is there a reason to build these from source, rather than using the
GnuWin32 binaries:
http://gnuwin32.sourceforge.net/packages/jpeg.htm
http://gnuwin32.sourceforge.net/packages/tiff.htm
Ideally, we should build as little as possible ourselves.
