[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm garbled when NVIZ is not top window
GRASS GIS trac at osgeo.org
Sat Mar 29 04:55:52 EDT 2008
  Reporter:  dylan    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  NVIZ openGL
Comment (by glynn):
 Replying to [comment:6 msieczka]:
 > On my system unless I export GRASS_NO_GLX_PIXMAPS=TRUE, NVIZ crashes at
 saving image as maximum resolution PPM, with the following error:
 I've made some more changes so that it will (hopefully) fall-back to using
 the window if using a GLXPixmap fails. You'll still get the X error
 message, but it shouldn't be fatal.
Ticket URL: <http://trac.osgeo.org/grass/ticket/104#comment:13>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
