[GRASS-dev] Re: [GRASS GIS] #104: saving display to tiff or ppm
garbled when NVIZ is not top window
Glynn Clements
glynn at gclements.plus.com
Sat Mar 29 07:44:14 EDT 2008
GRASS GIS wrote:
> #104: saving display to tiff or ppm garbled when NVIZ is not top window
> Comment (by msieczka):
> Replying to [comment:13 glynn]:
> > I've made some more changes so that it will (hopefully) fall-back to
> using the window if using
> > a GLXPixmap fails. You'll still get the X error message, but it
> shouldn't be fatal.
> Still after this change same crash, and still GRASS_NO_GLX_PIXMAPS=TRUE
> prevents it.
Oh, so it creates the GLXPixmap okay, but if you try to select it for
rendering it simply terminates the program (rather than just returning
False). IOW, there's no way to test whether or not the feature can be
used.
Well, there's not much that we can do about that, other than simply
not using it.
