Providing source code along with binaries - was Re: [GRASS-dev] WinGRASS-6.3.0RC5 Self Installer
Markus Neteler neteler at osgeo.org
Sun Mar 30 04:42:30 EDT 2008
Frank,
On Wed, Mar 26, 2008 at 3:27 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>  >> What exactly is the issue: is it limited disk space on the OSGeo
>  >> servers ?
>  Folks,
>  I would note that the past space constraints on download.osgeo.org are
>  now largely relaxed.  There is roughly 70GB of space available now.
please note that grass.osgeo.org is on a different machine:
[neteler at xblade14-2 mswindows]$ df -h .
Filesystem            Size  Used Avail Use% Mounted on
/dev/hda1              25G   18G  5.7G  76% /
Best
Markus
>  This space will be used over a number of projects (hopefully over a number
>  of years) so some prudence is a good idea, if only to keep the amount of
>  stuff needing to be managed, backed up, rsynced and so forth managable.
>  Best regards,
>  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  light and sound - activate the windows | http://pobox.com/~warmerdam
>  and watch the world go round - Rush    | President OSGeo, http://osgeo.org
>  _______________________________________________
>  grass-dev mailing list
>  grass-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
