[GRASS-dev] Re: grass-dev Digest, Vol 23, Issue 112
Glynn Clements
glynn at gclements.plus.com
Sun Mar 30 05:17:39 EDT 2008
Michael Barton wrote:
> > Date: Fri, 28 Mar 2008 23:24:36 +0600
> > From: Ivan Shmakov <ivan at theory.asu.ru>
> > Subject: [GRASS-dev] gui/tcltk/gis.m/*.tcl: wrong `variable' syntax
> > To: grass-dev at lists.osgeo.org
> > Cc: Ivan Shmakov <oneingray at gmail.com>
> > Message-ID: <m263v67odn.fsf at cherry.siamics.int>
> > Content-Type: text/plain; charset=us-ascii
> > The lines marked ``>'' below seem nonsensical to me. For what
> > reason, e. g., would one need to assign to an `array' variable
> > thrice, let alone introducing the `#' variable?
> > barscale.tcl 12 namespace eval GmBarscale {
> > barscale.tcl 13 > variable array opt # barscale current options
> > barscale.tcl 14 variable count 1
> > barscale.tcl 15 > variable array lfile # scale
> > barscale.tcl 16 > variable array lfilemask # scale
> > barscale.tcl 17 variable optlist
> > barscale.tcl 18 variable first
> > barscale.tcl 19 > variable array dup # layer
> > barscale.tcl 20 > variable placement #LabelEntry widget for
> > scale bar placment coordinates
> > barscale.tcl 21 };
> Ivan,
> Everything following the # is a comment to document the variable
No it isn't. It may have been *intended* as a comment, but the #
character is only treated as starting a comment when it occurs at the
beginning of a command, e.g. at the beginning of a line, or following
a semicolon.
>From the Tcl(n) manpage:
[9] Comments.
If a hash character (``#'') appears at a point where Tcl is
expecting the first character of the first word of a command,
then the hash character and the characters that follow it, up
through the next newline, are treated as a comment and ignored.
The comment character only has significance when it appears at
the beginning of a command.
It's quite common for people to get bitten by this. Most of the time,
you just get a syntax error, but in this case the code is legal (it
just doesn't do what you expect).
> There is one place that is a serious problem where we could really
> use a much more experienced TclTk programmer like you to sort out:
> the progress bar. It seems like it ought to be straightforward, but
> there is something wrong with the progress bar code so that if a
> module executes too quickly, it crashes the entire TclTk interface.
AFAICT, the issue is due to an event handler being re-entered through
the "update" command.
I note that ProgressBar::_modify calls update. One option is to remove
that call. Any other options (i.e. allowing event handlers to be
re-entered) are quite complex.
