[GRASS-dev] Re: [GRASS GIS] #74: Tcl version of v.digit's background colour doesn't work
GRASS GIS trac at osgeo.org
Sun Mar 30 08:24:32 EDT 2008
  Reporter:  craigleat  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  reopened
  Priority:  minor      |   Milestone:  6.3.0
 Component:  default    |     Version:  svn-trunk
Resolution:             |    Keywords:  v.digit, Tcl
Changes (by hamish):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Glynn:
 > I think I've fixed this with r30805.
 The background color is now white, but changing the background color from
 the Setting window Symbology tab (1st item) still doesn't work as
 expected.
 With r30810 (just committed) it now respects the bg color, but only if you
 add a background command like 'd.grid 5000'. I also notice that you can't
 turn off background commands once created, unchecking their tick boxes has
 no visible effect, once rendered. (if not yet rendered it won't draw it if
 unticked)
 To make the bg cmd go away you need to fully delete the command text.
 (putting a # at the start of the line could work too? but not well)
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:4>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
