[GRASS-dev] Re: grass-dev Digest, Vol 23, Issue 112
Ivan Shmakov ivan at theory.asu.ru
Sun Mar 30 14:17:48 EDT 2008
>>>>> Michael Barton <michael.barton at asu.edu> writes:
 >> The lines marked ``>'' below seem nonsensical to me.  For what
 >> reason, e. g., would one need to assign to an `array' variable
 >> thrice, let alone introducing the `#' variable?
 >> barscale.tcl	15 >	    variable array lfile # scale
 > Ivan,
 > Everything following the # is a comment to document the variable
	As Glynn had already pointed out, it isn't.
 > The "variable xxx"
 > is to assign this to a local namespace.
	But note that there's no `variable array VARN' form.  I guess,
	the intended effect could be achieved by something like:
   variable  VARN
   array set VARN { }
	Or, introducing a new procedure:
proc var-array { varn } {
    uplevel 1 [ list variable  $varn ]
    uplevel 1 [ list array set $varn { } ]
   var-array VARN
