[GRASS-dev] patch for v.voronoi/v.delaunay
Hamish
hamish_b at yahoo.com
Sat May 3 01:41:00 EDT 2008
> Markus wrote:
> > It seems that the precision gets somewhere lost in
> > db_convert_column_value_to_string()
> > i.e. lib/db/dbmi_base/columnfmt.c
> > but I don't find where is is rounded.
Hamish:
> lib/db/dbmi_base/valuefmt.c db_convert_value_to_string() does:
> case DB_C_TYPE_DOUBLE:
> sprintf (buf, "%lf",db_get_value_double(value));
> G_trim_decimal(buf);
> the %lf is rounding to %.6f?
> maybe
> - "%lf"
> + "%.14f"
> then let G_trim_decimal() remove any extra .00000s.
> but maybe such noisy output is not always wanted. :-/
> (e.g. pretty output for d.what.vect tcl form)
> FWIW v.out.ascii defaults to dp=8.
> for the v.colors script, SQL "select * WHERE dbl_col = <FP number>" is
> always going to be problematic.
> the C way:
> if( abs(test - value) < GRASS_EPSILON )
In the case of v.colors, the SQL set loop could be rewritten to avoid
this problem by matching to the cat number, not trying to logically match
the FP value.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
