[GRASS-dev] Changes to MAKE System for SCRIPTS
roberto.marzocchi
roberto.marzocchi at gmail.com
Sat May 3 08:07:50 EDT 2008
Markus Neteler ha scritto:
> Robert,
> I have added a (draft) Makefile to that directory. Please check.
I've make some changes to Makefile, because before the Makefile created
a uncorrect directory.
Now there is only one more problem:
*the clean lines don't remove correctly the binaries*
/clean:
-rm -f find_main_channel.exe clean_inundation.exe 2d_path.exe
correction_from_path.exe dati.mod dd.mod
Anyone have an idea?
> Now you can simplify your script and call the F90 based binaries
> directly like
> $GISBASE/etc/fortran_code/find_main_channel
> etc.
Yes I did.
> instead of (script excerpt):
> rm -r -f ~/$cartella_nascosta
> mkdir ~/$cartella_nascosta
> cp "$GISBASE/fortran_code"/find_main_channel.exe ~/$cartella_nascosta
> cp "$GISBASE/fortran_code"/clean_inundation.exe ~/$cartella_nascosta
> cp "$GISBASE/fortran_code"/2d_path.exe ~/$cartella_nascosta
> cp "$GISBASE/fortran_code"/correction_from_path.exe ~/$cartella_nascosta
> cheers,
> Markus
Cheers
Roberto
> On Fri, May 2, 2008 at 5:49 PM, roberto.marzocchi
> <roberto.marzocchi a gmail.com> wrote:
>> Hello,
>> I've write a grass script
>> (https://svn.osgeo.org/grass/grass-addons/raster/r.inund.fluv/) In my grass
>> script I use four implemented fortran codes.
>> Now this script is in Add_ons repository, but there isn't a Makefile. I've
>> written an install.sh script.
>> With Markus, we think that is good to make some changes to the MAKE system
>> and to allow the compilation of Fortan codes.
>> probably is like the compilation of C codes
>> We wrote some lines in install.sh script (see below), but we're sure that
>> this can be written more elegant in make syntax.
>> #compile the fortran codes with GNUFORTRAN
>> #gfortran -O1 -o trova_alveo.exe trova_alveo.f90
>> #gfortran -O1 -o pulizia_inondazione.exe
>> pulizia_inondazione.f90
>> #gfortran -O1 -o reticolo2d.exe reticolo2d.f90
>> #gfortran -O1 -o correzione_reticolo.exe
>> correzione_reticolo.f90
>> # put the .exe files in the chosen directory and change the
>> 219-222 rows of the script
>> Anyone may help me?
>> Thanks in advanced
>> Roberto
>> grass-dev mailing list
>> grass-dev a lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080503/0f84f036/attachment.html
