[GRASS-dev] [GRASS GIS] #155: ps.map: the "M" highlight problem
trac at osgeo.org
Sat May 3 14:36:14 EDT 2008
Reporter: perk | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: ps.map highlight |
Using any highlight on `text` and `labels` produces some very bad looking
results. I call this the "M" problem, because I first noticed it in
labels with a capital M, but other letters are affected too. I've
attached a sample that pretty clearly shows the problem.
I see two pretty easy ways to fix this: temporarily change (1) the miter
length or (2) the line join style when the highlight path gets stroked.
I've chosen the latter, because I think it looks better. I've attached a
patch for ps/ps.map/prolog.ps. It is marked as a binary file for some
reason, so I was not able to do "svn diff". I've also attached the same
ps.map output sample made after the fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/155>
