[GRASS-dev] GRASS 7 raster coding best practices
Yann Chemin
yann.chemin at gmail.com
Sat May 3 20:00:26 EDT 2008
2008/5/4 Glynn Clements <glynn at gclements.plus.com>:
> Yann Chemin wrote:
> > Same goes for G_OPT_R_OUTPUT, but I could not find it for parameters
> > in float format (G_OPT_F_INPUT?) for example...
> Huh? What would be the settings for such an option?
input = G_define_option(G_OPT_F(D?)_INPUT) ;
input->key =_("parameter");
input->type = TYPE_DOUBLE;
input->required = YES;
input->gisprompt =_("value, parameter");
input->description=_("Value of the parameter");
/*input->answer =_("0.000");*/
input->guisection = _("Required");
I could also think similarly for non-GRASS files actually
(configuration files sometimes need to be loaded separately, i.e.
i.atcorr, btw I cant find it anymore in grass70).
> > In another module (r.slope.aspect), I found an interesting code opennew():
> > #include <stdlib.h>
> > #include <grass/gis.h>
> > #include <grass/glocale.h>
> > int opennew (char *name, RASTER_MAP_TYPE wr_type){
> > int fd;
> > if (G_legal_filename (name) < 0)
> > G_fatal_error (_("<%s> is an illegal file name"), name);
> > if(wr_type < 0) /* default fp type */
> > fd = G_open_fp_cell_new (name);
> > else
> > fd = G_open_raster_new (name, wr_type);
> > if (fd < 0)
> > G_fatal_error (_("Failed in attempt to open %s"), name);
> > return fd;
> > Sorry, i squashed it a bit for the email.
> > Well, this could be interesting to also include a similar code in main GRASS,
> > so we could reduce some coding length and ultimately clarify it.
> I'm not sure that the above warrants a separate function.
> First, the G_legal_filename() call is redundant; G_open_*_new()
> already contain that check.
> Second, I would prefer it if G_open_*_new() simply called
> G_fatal_error() themselves if an error occured. It's not as if there's
> any reasonable alternative way to handle the error.
Yes, +1 for this.
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
