[GRASS-dev] Re: [GRASS GIS] #155: ps.map: the "M" highlight problem
trac at osgeo.org
Sun May 4 03:51:33 EDT 2008
Reporter: perk | Owner: hamish
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: ps.map highlight text labels
Changes (by hamish):
* status: new => assigned
* owner: grass-dev at lists.osgeo.org => hamish
* cc: grass-dev at lists.osgeo.org (added)
Comment:
nice to finally see a solution for this, thanks.
before applying the patch I would like to ask about possible side effects
-- does the "currentlinejoin 1 setlinejoin stroke setlinejoin" part need
to be swiched off after drawing the labels, or will it be self contained?
could a similar technique be used to connect .eps pattern tiles?
eg broken lines: http://grass.osgeo.org/wiki/Psmap_flooding_example
you might also see that d.labels does not do very well with larger values
for the highlight width. In that case I guess the solution is to also
smear the color using the "knight's move" or similar, not just the 8
cardinal+ordinal directions.
> I've attached a patch for ps/ps.map/prolog.ps. It is marked as a binary
file
> for some reason, so I was not able to do "svn diff".
$ svn proplist prolog.ps
Properties on 'prolog.ps':
svn:mime-type
$ svn propget svn:mime-type prolog.ps
application/postscript
$ svn diff prolog.ps
Index: prolog.ps
Cannot display: file marked as a binary type.
svn:mime-type = application/postscript
svn bug? (PostScript is ASCII)
fwiw, trac does nice markup when you click on the .diff file.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/155#comment:2>
