[GRASS-dev] GRASS 7 raster coding best practices
Yann Chemin
yann.chemin at gmail.com
Sun May 4 05:39:44 EDT 2008
> > > > input->guisection = _("Required");
> > > FWIW I consider this to be redundant noise. If it is wished that the
> > > module GUI(s) group required options in the first tab then they
> > > should extract that from the input->required field.
> > Can you provide an example of filling in input->required, that would
> > be nice to add.
> you already have it above; =YES or =NO.
OK, a small misunderstanding here, some small examples.
input->guisection will create a Tab in the GUI with the name given to it.
input->guisection = _("Optional");
input->guisection = _("Set of functions 1");
input->guisection = _("Parameters for output2");
on the other hand,
input->required=YES
forbids the code to run on empty "input"
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
