[GRASS-dev] GRASS 7 raster coding best practices
Glynn Clements
glynn at gclements.plus.com
Mon May 5 00:52:32 EDT 2008
Yann Chemin wrote:
> > > Same goes for G_OPT_R_OUTPUT, but I could not find it for parameters
> > > in float format (G_OPT_F_INPUT?) for example...
> > Huh? What would be the settings for such an option?
> input = G_define_option(G_OPT_F(D?)_INPUT) ;
Presumably that should be G_define_standard_option()?
> input->key =_("parameter");
> input->type = TYPE_DOUBLE;
> input->required = YES;
> input->gisprompt =_("value, parameter");
> input->description=_("Value of the parameter");
> /*input->answer =_("0.000");*/
> input->guisection = _("Required");
I can't see any use for that. In practice, you would probably end up
manually overriding as many settings as if you had just used
G_define_option(). E.g. I doubt that either the ->key or ->description
fields would be left untouched.
Also, the ->gisprompt setting is completely bogus; the string is never
localised, and neither "value" nor "parameter" are valid keys.
