[GRASS-dev] [GRASS GIS] #156: new attribute in Option struct to
allow conditional options requirement
trac at osgeo.org
Mon May 5 02:35:30 EDT 2008
#156: new attribute in Option struct to allow conditional options requirement
Reporter: martinl | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: parser, required, conditional |
In some cases "naturally" required parameter cannot be mark as "required"
because there are flags/parameters which don't require that parameter at
all. E.g. r.in.gdal doesn't require for 'f' flag (list supported formats)
any other parameter. Otherwise 'input' is required. To mark 'input' as
required for GRASS parser is counter-productive, user would be forced to
type
r.in.gdal -f in=dummy
instead of
r.in.gdal -f
On the other hand for GUI dialogs is more reasonable to mark visually
'input' as required (for most users can be confusing to see 'input' as
optional when importing data into GRASS). Currently there is not so nice
workaround for that.
opt->guisection="Required";
which puts given parameter to 'Required' tab in GUI dialog.
This can be solved with a new attribute in Option struct which tells the
parser not to worry about testing all required options=. E.g.
input_opt->required=YES;
f_flag->suppress_required=YES;
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/156>
