[GRASS-dev] Re: [GRASS GIS] #155: ps.map: the "M" highlight problem
trac at osgeo.org
Mon May 5 16:47:09 EDT 2008
Reporter: perk | Owner: hamish
Type: defect | Status: assigned
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: ps.map highlight text labels
Comment (by glynn):
Replying to [comment:4 perk]:
> > before applying the patch I would like to ask about possible side
effects -- does the "currentlinejoin 1 setlinejoin stroke setlinejoin"
part need to be swiched off after drawing the labels, or will it be self
contained?
> This should be self-contained. "currentlinejoin" puts the current line
join style on the Postcript stack, "1 setlinejoin" sets the join style to
rounded, "stroke" draws the current path (does not affect the stack), and
the final "setlinejoin" uses the value put on the stack earlier to return
the join style to the previous value.
The normal way to make temporary changes to the rendering state is with
gsave/grestore, e.g.:
gsave 1 setlinejoin stroke grestore
Ticket URL: <http://trac.osgeo.org/grass/ticket/155#comment:5>
