[GRASS-dev] Are the recursive calls a problem in Grass?
Markus Neteler
neteler at osgeo.org
Tue May 6 11:14:37 EDT 2008
Roberto,
please try it on command line. Maybe then the error becomes
visible (GUI may catch it silently).
Markus
On Tue, May 6, 2008 at 1:59 PM, roberto caselli
<roberto.caselli at yahoo.it> wrote:
> Does anyone have an idea or an advice for this problem? GRASS doens't give
> me any kind of error message so I don't undestand where the bug is. It just
> stop the execution! I hope in your experience.
> Regards,
> Roberto
> roberto caselli <roberto.caselli at yahoo.it> ha scritto:
> Hello everyone,
> I have a question for you. I'm working on a module that uses a recursive
> call to flow water from a cell to its neighbours. I tested it with some
> sample raster map but I didn't see any kind of output on the screen. I saw
> GRASS started running (i saw the green dressed runner above on the right)
> and then it stopped with the RUN button available to be pushed again.
> I tried to comment the recursive call and everything went well. (I saw the
> partial results of the execution of my module on the screen).
> So I think the problem is due to this recursive call and I'd like to know if
> there is a way to fix this problem.
> Regards,
> Roberto
> ________________________________
> Tante idee per la salvaguardia del pianeta su
> Yahoo! for good.
> Yahoo! for good.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
