[GRASS-dev] Are the recursive calls a problem in Grass?
roberto caselli
roberto.caselli at yahoo.it
Tue May 6 15:18:23 EDT 2008
Thak you very much! Now I can see the message error:
the message is the follow:
Segmentation fault (core dumped)
Martin Wegmann <wegmann a biozentrum.uni-wuerzburg.de> ha scritto: Hello Roberto,
On Dienstag, 6. Mai 2008 20:45:46 roberto caselli wrote:
> I always start my application from command line and the a GUI window
> opens so I can write the input and press the RUN button. But I don't
> see any kind of message error inside that window.
I don't have your module command currently hence an example with a common
command:
if you do e.g.
d.rast
the GUI will pop up, if you do
d.rast --help
you will see syntax
d.rast [-oix] map=string [catlist=cat[-cat][,cat[-cat],...]]
[vallist=val[-val][,val[-val],...]] [bg=color] [--verbose] [--quiet]
the parts in brackets are optional hence you just have to to enter
d.rast map=your_raster
to plot the raster.
If you do the same with your command you will get an error message (or not).
You can change the message output with
g.gisenv set=debug=5 (not too sure about that)
hope this helps, cheers, Martin
> Roberto
> Roberto,
> please try it on command line. Maybe then the error becomes
> visible (GUI may catch it silently).
> Markus
> On Tue, May 6, 2008 at 1:59 PM, roberto caselli
> wrote:
> > Does anyone have an idea or an advice for this problem? GRASS doens't
> give
> > me any kind of error message so I don't undestand where the bug is.
> It just
> > stop the execution! I hope in your experience.
> > Regards,
> > Roberto
> > roberto caselli ha scritto:
> > Hello everyone,
> > I have a question for you. I'm working on a module that uses a
> recursive
> > call to flow water from a cell to its neighbours. I tested it with
> some
> > sample raster map but I didn't see any kind of output on the screen.
> I saw
> > GRASS started running (i saw the green dressed runner above on the
> right)
> > and then it stopped with the RUN button available to be pushed again.
> > I tried to comment the recursive call and everything went well. (I
> saw the
> > partial results of the execution of my module on the screen).
> > So I think the problem is due to this recursive call and I'd like to
> know if
> > there is a way to fix this problem.
> > Regards,
> > Roberto
> > ________________________________
> > Tante idee per la salvaguardia del pianeta su
> > Yahoo! for good.
> > Yahoo! for good.
> > grass-dev mailing list
> > grass-dev a lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Yahoo! for good.
__________________________________________________
Do You Yahoo!?
Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da tanto spazio gratuito per i tuoi file e i messaggi
http://mail.yahoo.it
Un allegato HTML ? stato rimosso...
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080506/a43f033b/attachment.html
