[GRASS-dev] Re: [GRASS GIS] #155: ps.map: the "M" highlight problem
trac at osgeo.org
Wed May 7 01:05:49 EDT 2008
Reporter: perk | Owner: hamish
Type: defect | Status: closed
Priority: minor | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: fixed | Keywords: ps.map highlight text labels
Changes (by hamish):
* status: assigned => closed
* resolution: => fixed
Comment:
thanks, applied in SVN relbr6 + trunk.
In SVN you do not have to mark a binary file as binary to avoid unwanted
newline translation. But you do set file properties, be they an executable
bit or a mime-type. In this case the mime type is set for a postscript
file, but SVN is misconfigured to think that those are binary files when
they are not.
more on svn propset:
http://trac.osgeo.org/grass/wiki/HowToSVN#Fileproperties
thanks again,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/155#comment:7>
