[GRASS-dev] Re: [GRASS-user] Cannot use grass on vfat partition
Maris Nartiss
maris.gis at gmail.com
Wed May 7 07:40:06 EDT 2008
Hi all,
I changed that ugly PERMANENT check in gis_set.tcl file, but IMHO it
will not help in this case, as tcl (gis_set.tcl), shell (init.sh) and
C modules (g.region and firends) still will work in case-sensitive way
in case-sensitive systems (Linux and other Unix-like systems). IMHO
this should be just added to list of known issues.
Correct me, if I'm wrong.
Maris.
2008/5/2, Glynn Clements <glynn at gclements.plus.com>:
> Agustin Lobo wrote:
> > Thanks, solved by adding shortname=win95 to the mount options in
> /etc/fstab
> > Should a bug report be filled? by me?
> > Should I write a note in the wiki?
> A note in the Wiki would be good, if you can figure out where to put
> it.
> A bug report is problematic because it isn't clear where the bug lies.
> The handling of PERMANENT is a bug, but won't normally get triggered
> in practice. I can't see where the incorrect test for MYNAME or WIND
> lies.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
