[GRASS-dev] Re: [GRASS GIS] #65: Starting up gis.m& hangs (probably on g.region)
GRASS GIS trac at osgeo.org
Thu May 8 15:46:36 EDT 2008
  Reporter:  pvbgis   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  reopened
  Priority:  major    |   Milestone:  6.3.1
 Component:  default  |     Version:  6.3.0 RCs
Resolution:           |    Keywords:  wingrass
Comment (by 4everskiff):
 Replying to [comment:6 pvbgis]:
 > One additional point, the g.region -p command does also work in the
 MINGW32 command line screen (when in GRASS obviously). But not g.region
 without the -p flag, which freeses the MINGW32 screen. In the normal
 Windows command screen in GRASS, typing g.region does not seem to do
 anything.
 Hi Pauolo,
 I'm trying to understand. Did you installed WinGRASS-6.3.0 using the
 installer?
 Did you uninstalled the previous GRASS installations before to install the
 new one?
 What does happen exactly when do you click on the GRASS icon on your
 desktop?
 Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:7>
