[GRASS-dev] Re: [GRASS GIS] #65: Starting up gis.m& hangs (probably
on g.region)
trac at osgeo.org
Thu May 8 16:40:21 EDT 2008
#65: Starting up gis.m& hangs (probably on g.region)
Reporter: pvbgis | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.3.1
Component: default | Version: 6.3.0 RCs
Resolution: | Keywords: wingrass
Comment (by 4everskiff):
Replying to [comment:8 pvbgis]:
> - I get the startup screen, after which I select the project location /
mapset and click on 'Enter Grass'.
What location? demolocation?
> Than, the 3 screens Output-GIS.m, Map Display 1 and GRASS.3.0 GIS
Manager open, but the first two are white.
normal
>Nothing further happens, and when I click on the Gis Manager screen, I
get the 'Not Responding' message in the Title bar of that screen.
not normal! it's difficult to understand what is happening...
you could try to install FileMon [1] and record the system calls, and try
to understand what is gong wrong...
[1] http://technet.microsoft.com/en-us/sysinternals/bb896642.aspx
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:9>
