[GRASS-dev] Re: build problems on Mac OS X 10.5.2.
John Kern
kernj at kernj.cnc.net
Thu May 8 22:44:45 EDT 2008
Hello,
I just realized I forgot to mention I am working off the Grass 6.3
branch.
-John
On May 8, 2008, at 7:26 PM, John Kern wrote:
> Hello,
> I am trying to build Grass from source on Leopard(Mac OS X 10.5.2
> with gcc 4.0.1).
> While PROJ.4 built and installed without problem, configure failed
> for GRASS proper. The resulting error is ...
> "checking External PROJ.4 version... configure: error: *** Could not
> determine External PROJ.4 version."
> Consider this line from the trace output of the configure script.
> + eval echo configure:6910: '"${CC-cc}' -o conftest '$CFLAGS'
> '$CPPFLAGS' '$LDFLAGS' 'conftest.$ac_ext' '$LIBS' '1>&5"'
> ++ echo configure:6910: 'gcc -o conftest.dSYM -g -O2
> conftest.c 1>&5'
> The dSYM file extension on the output file is the critical bit. If
> the output file ends with a dSYM file extension, only supporting
> data is generated. No executable. (see example below). I worked
> around the problem by deleting references to ${ac_exeext}. What's
> the right fix for the configure script? Apparently there is a
> supporting script to autoconf which needs to be updated, right?
> Sincerely,
> -John
> %%% with file extension - no executable
> [Macintosh:grass/grass63_release/try] jkern% gcc -o try.dSYM -g -O2
> try.c
> [Macintosh:grass/grass63_release/try] jkern% ls -l
> total 8
> -rw-r--r-- 1 jkern staff 171 May 2 16:04 try.c
> drwxr-xr-x 3 jkern staff 102 May 8 18:02 try.dSYM
> [Macintosh:grass/grass63_release/try] jkern% ls -R
> try.c try.dSYM
> ./try.dSYM:
> Contents
> ./try.dSYM/Contents:
> Info.plist Resources
> ./try.dSYM/Contents/Resources:
> DWARF
> ./try.dSYM/Contents/Resources/DWARF:
> try.dSYM
> %%%% without the extension - all is well.
> [Macintosh:grass/grass63_release/try] jkern% gcc -o try -g -02 try.c
> total 40
> -rwxr-xr-x 1 jkern staff 12832 May 8 19:24 try
> drwxr-xr-x 3 jkern staff 102 May 8 19:24 try.dSYM
