[GRASS-dev] WinGRASS: r.in.gdal projection issue
Michael Barton
michael.barton at asu.edu
Sat May 10 01:30:01 EDT 2008
Marco,
I reported something similar a month or so back. Some of my students using
WinGRASS would import an SRTM or other file--or they would make a location
from an EPSG code. Then when they tried to reproject into another location,
they'd get an error that there is no projection file.
It seems most common (only?) with some latlon locations. UTM's seem OK. It
is also somewhat erratic. I assume that it is either a g.proj error or a bad
EPSG entry.
Michael
On 5/9/08 8:35 PM, "grass-dev-request at lists.osgeo.org"
<grass-dev-request at lists.osgeo.org> wrote:
> Message: 1
> Date: Fri, 9 May 2008 18:38:01 +0200
> From: <marco.pasetti at alice.it>
> Subject: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
> To: <marco.pasetti at alice.it>, <grass-dev at lists.osgeo.org>
> Message-ID:
> <FA8A693893F4CE4283B4473C79FA47D505BB41CF at FBCMST06V02.fbc.local>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi all,
> I also tried to launch GRASS with GISBase without spaces (such as C:\GISBASE),
> with the demolocation, and placing the input file (Z_39_3.ASC) in a path
> without spaces too (C:\), but I got the same result.
> Marco
> PS: VMware seems to not be a good solution, it requires a too performant
> hardware; I'll go back with the linux dual boot solution.
> ________________________________
> Da: grass-dev-bounces at lists.osgeo.org per conto di marco.pasetti at alice.it
> Inviato: ven 09/05/2008 16.51
> A: grass-dev at lists.osgeo.org
> Oggetto: [GRASS-dev] WinGRASS: r.in.gdal projection issue
> Hi all,
> During WinGRASS 6.3.0 testings I encontered a problem with the r.in.gdal
> module: it reports no errors, and correctly import rasters, but fails creating
> the projection for the new location created during raster import.
> I explain better with an example: I imported an SRTM tile, to be imported in a
> new location named "test", with the following command line:
> r.in.gdal {input=C:/Documents and Settings/Marco/Documenti/GIS Data
> Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC} output=Z_39_3.dem location=test
> At the end of the Run it reports as follows in the output window:
> Location <test> created
> r.in.gdal complete.
> After that I exit GRASS and I restart it accessing the location test: the
> raster have been correctly imported, the region set to the raster boundaries,
> but if type:
> g.proj -j
> it reports
> XY (unprojected)
> talking in IRC with a linux huy, I asked him to do the same command using the
> same raster with GRASS-6.3.0SVN: the location test, for him, has a correct
> projection (that is latlong wgs84 and so on...). So I guess that is a windows
> problem, but I don't really know why since the command doesn't report errors!
> any suggestions?
> This said I have another question for you: I have linux (ubuntu) installed on
> my system with xual boot along with xp pro sp2, but it's really impossible to
> me to always reboot within the two systems to make tests, so today I decided
> to install VMware with an ubuntu (8.04) virtual machine. I would use this VM
> to make tests on GRASS and directly check if WinGRASS problems are strictly
> referred to windows platform or to other problems. Now I have a doubt:
> 1. Install GRASS from a destributed package or
> 2. Manually compile and install all the needed dependencies (if not already
> intalled, obviously) with the same support configuration as I did for the
> current WinGRASS release, in order to check if WinGRASS errors are generated
> by dependency issues and not by platform problems?
> Thanks for your help,
> Regards
> Marco
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/grass-dev/attachments/20080509/1255b67d/attac
> hment-0001.html
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
