R: R: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
marco.pasetti at alice.it
Mon May 12 04:56:18 EDT 2008
Hi Hamish,
>no coordinate system is defined == XY
yes, it seemed the same to me (I also opened the ASC file and I didn't find any information about the projection), but a linux user on IRC did the same command (on my request) and told me that on linux it created the location 'test' with proj defined.
>any support files come with it that supply that information?
no. There's only the MASK file, but I haven't it because the file is not available on the server.
The best thing is that someone else could try to import the same file [1] with the same command.
[1] http://srtm.jrc.it/SRTM_Data_ArcAscii/srtm_39_03.zip
Regards,
Marco
Da: Hamish [mailto:hamish_b at yahoo.com]
Inviato: lun 12/05/2008 10.42
A: marco.pasetti at alice.it
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: R: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
Marco:
> >gdalinfo filename
> gdalinfo {C:/Documents and Settings/Marco/Documenti/GIS
> Data Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC}
> output:
> Driver: AAIGrid/Arc/Info ASCII Grid
> Files: C:/Documents and Settings/Marco/Documenti/GIS Data
> Size is 6000, 6000
> Coordinate System is `'
no coordinate system is defined == XY.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080512/503ad95c/attachment.html
