R: R: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
marco.pasetti at alice.it marco.pasetti at alice.it
Mon May 12 05:43:13 EDT 2008
Hi Paul,
>I get a 404 not found error on that file.
sorry, I supposed that is was working. The following works, I checked it out:
http://srtm.jrc.it/SRTM_Data_ArcAscii/srtm_39_03.zip <http://srtm.jrc.it/SRTM_Data_ArcAscii/srtm_39_03.zip>
>Probably though there is simply no projection information present?
Yes, I suppose. But why the guy on IRC told me that it worked for him? Did he lie?
Marco
Da: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
Inviato: lun 12/05/2008 11.28
A: marco.pasetti at alice.it
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: R: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
On Mon, 12 May 2008 marco.pasetti at alice.it wrote:
> Hi Paul,
>> How big is the file? Would it be possible to put it somewhere for me to
>> have a look at and try and reproduce the behaviour?
> the file is available here:
> http://armadillo.geog.kcl.ac.uk/portal/srtm3/srtm_data_arcascii/srtm_39_03.zip <http://armadillo.geog.kcl.ac.uk/portal/srtm3/srtm_data_arcascii/srtm_39_03.zip>
> (I selected the server nearest to you)
>> gdalinfo filename
> gdalinfo {C:/Documents and Settings/Marco/Documenti/GIS Data Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC}
> output:
> Driver: AAIGrid/Arc/Info ASCII Grid
> Files: C:/Documents and Settings/Marco/Documenti/GIS Data Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC
> Size is 6000, 6000
> Coordinate System is `'
As Hamish said, this means the file doesn't contain projection
information. Or if it does, GDAL can't read it, thus not a GRASS problem.
Paul
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080512/cd632996/attachment.html
