[GRASS-dev] [GRASS GIS] #165: compilation error
trac at osgeo.org
Tue May 13 11:11:09 EDT 2008
Reporter: watti | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.1
Component: default | Version: svn-trunk
Keywords: |
when compiling Grass 6.3 on RHEL 4 64 bit I get the following errors
Errors in:
/data/users/soi534/GRASS/grass63_release/lib/gmath
/data/users/soi534/GRASS/grass63_release/lib/imagery
going to the directories
/lib/gmath:
-gnu/svd.o -lgrass_gis -lgrass_datetime -lz -lfftw3 -lm && \
(cd /data/users/soi/GRASS/grass63_release/dist.x86_64-unknown-linux-
gnu/lib; ln -f -s libgrass_gmath.6.3.1svn.so
gnu/lib/libgrass_gmath.so)
/usr/bin/ld: /usr/local/lib/libfftw3.a(mapflags.o): relocation R_X86_64_32
against `a local symbol' can not be used when making a shared object;
recompile with -fPIC
/usr/local/lib/libfftw3.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/data/users/soi/GRASS/grass63_release/dist.x86_64-unknown-
linux-gnu/lib/libgrass_gmath.6.3.1svn.so] Error 1
in /lib/imagery I get the error propagation
/usr/bin/ld: cannot find -lgrass_gmath
same in /lib/rst/interp_float
I use fftw-3.1.2.
Any suggestions ?
Cheers,
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/165>
