[GRASS-dev] Re: [GRASS GIS] #166: short integer overflow with
r.in.gdal
trac at osgeo.org
Tue May 13 13:59:50 EDT 2008
#166: short integer overflow with r.in.gdal
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: gdal
Changes (by dylan):
* keywords: gdal r.in.gdal => gdal
Comment:
This appears to be a problem with GDAL not recognizing the ASCII grid data
type, as GDAL-specific operations such as gdal_translate produce erroneous
results. GDAL is interpreting the attached input file as Int16.
Using the attached file:
gdal_translate big_int_arc_file.asc test.tiff
the resulting file is produced:
gdalinfo -stats test.tiff
Driver: GTiff/GeoTIFF
Files: test.tiff
Size is 7, 7
Coordinate System is `'
Origin = (592000.000000000000000,4926000.000000000000000)
Pixel Size = (1000.000000000000000,-1000.000000000000000)
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 592000.000, 4926000.000)
Lower Left ( 592000.000, 4919000.000)
Upper Right ( 599000.000, 4926000.000)
Lower Right ( 599000.000, 4919000.000)
Center ( 595500.000, 4922500.000)
Band 1 Block=7x7 Type=Int16, ColorInterp=Gray
Minimum=-31293.000, Maximum=32420.000, Mean=216.837, StdDev=18087.589
NoData Value=-9999
Metadata:
STATISTICS_MINIMUM=-31293
STATISTICS_MAXIMUM=32420
STATISTICS_MEAN=216.83673469388
STATISTICS_STDDEV=18087.589140406
Ticket URL: <http://trac.osgeo.org/grass/ticket/166#comment:2>
