[GRASS-dev] Re: [GRASS GIS] #166: short integer overflow with
r.in.gdal
trac at osgeo.org
Tue May 13 18:08:09 EDT 2008
#166: short integer overflow with r.in.gdal
Reporter: dylan | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: gdal
Comment (by dylan):
Replying to [comment:3 dylan]:
> Since this is a GDAL bug, I will change the type to "task", and make a
new ticket on the GDAL tracker. The fix for now is to use r.in.arc for any
AA Grid files which contain large (32bit) integer data.
[http://trac.osgeo.org/gdal/ticket/2369 GDAL ticket] created.
Ticket URL: <http://trac.osgeo.org/grass/ticket/166#comment:4>
