[GRASS-dev] Re: [GRASS GIS] #165: compilation error
trac at osgeo.org
Wed May 14 05:37:04 EDT 2008
Reporter: watti | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.1
Component: default | Version: svn-trunk
Resolution: | Keywords:
Comment (by watti):
Replying to [comment:1 glynn]:
> See if you can get hold of shared FFTW libraries. Or maybe you already
have them and need to point --with-fftw-libs= to the right place.
> Or you could just build --without-fftw; there are only a handful of
modules which need it (i.fft, i.ifft, i.zc, r.surf.fractal).
I did some more research about the problem and solved it. The problem
arises from the -fPIC flag when compiling the Code. The FFTW configuration
script seems to assume it can not use -fPIC in the make file. see
http://www.gentoo.org/proj/en/base/amd64/howtos/index.xml?part=1&chap=3
for more details !
Cheers,
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/165#comment:2>
