[GRASS-dev] Make/Configure Issue using Eclipse/Windows
peter.loewe at gmx.de
Thu May 15 04:22:10 EDT 2008
Hi Glynn,
-------- Original-Nachricht --------
> Datum: Wed, 14 May 2008 19:12:08 +0100
> Von: Glynn Clements <glynn at gclements.plus.com>
> An: peter.loewe at gmx.de
> CC: grass-dev at lists.osgeo.org
> Betreff: Re: [GRASS-dev] Make/Configure Issue using Eclipse/Windows
> peter.loewe at gmx.de wrote:
> > I am trying to get GRASS compiled in a Eclipse/CDT environment on a
> Windows machine.
> > The approach includes wrapping the "configure / make /make install"
> -process in an ant file and works very well behaved on linux boxes.
> > On a windows box (using msys) "something" is going wrong regarding the
> header files. This is the first error produced by make, the follow-up errors
> are similar:
> > [exec] gcc
> > -I/d/Nutzer/ploewe/workspace/neo63/dist.i686-pc-mingw32/include
> > -IC:\msys\1.0\local\include -g -O2 -IC:\msys\1.0\local\include
> > -DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64
> > -o OBJ.i686-pc-mingw32/auto_mask.o -c auto_mask.c
> > [exec] In file included from auto_mask.c:17:
> > [exec] G.h:2:23: rpc/types.h: No such file or directory
> > [exec] G.h:3:21: rpc/xdr.h: No such file or directory
> > [exec] G.h:42: error: syntax error before "XDR"
> > [exec] G.h:42: warning: no semicolon at end of struct or union
> > [exec] G.h:47: error: syntax error before '}' token
> > [exec] make[3]: *** [OBJ.i686-pc-mingw32/auto_mask.o] Error 1
> > The GRASS sources have been downloaded from the SVN, so all files are
> available.
> > Suggestions, anyone ?
> Did you perform this step:
> http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html#Xdr
> I.e. does C:\msys\1.0\local\include\rpc\ exist?
Yes it does.
Still puzzled,
Peter
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/?mc=sv_ext_mf@gmx
