[GRASS-dev] Re: [GRASS GIS] #168: WinGRASS: i.ortho.photo fails
trac at osgeo.org
Thu May 15 06:12:35 EDT 2008
Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0
Resolution: | Keywords:
Comment (by marcopx):
Replying to [comment:1 hamish]:
> i.ortho.photo will not work in native MS-Windows. It needs xmons.
> The imagery/Makefile should ensure that it is only built if GRASS is
compiled with X11 support. Is the module present if you try from the
command line?
> Hamish
NO, you're right. Since I didn't have i.ortho.photo module in my *not
built modules* list after make command, I supposed that the monitors
problem was fixed in it (I didn't know that the make rules was changed).
Good to know, I have to add it to the missing modules list [1]
What are the other modules not built, over the ones already listed in [1]?
[1]
http://grass.osgeo.org/grass63/binary/mswindows/native/#Missing%20Modules
Thanks
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/168#comment:2>
