[GRASS-dev] Re: [GRASS GIS] #168: WinGRASS: i.ortho.photo fails
trac at osgeo.org
Thu May 15 21:04:33 EDT 2008
Reporter: 4everskiff | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.3.0
Resolution: | Keywords:
Comment (by glynn):
Replying to [comment:3 hamish]:
> Anything that needs X11 will not work.
To be precise, anything which requires monitors (X or otherwise) will not
work. The problem is the monitor/driver architecture, not X. We already
have libW11, which allows the use of XDRIVER under Cygwin without
requiring X.
In practice, it doesn't really matter, as anything which works with the
PNG driver will likely work with direct rendering. I only mention this in
case someone is thinking of fixing the issue, in which case it needs to be
remembered that it's not X which is the problem, but the communication
between the client and the monitor.
Ticket URL: <http://trac.osgeo.org/grass/ticket/168#comment:5>
