[GRASS-dev] [GRASS GIS] #171: d.vect: -c type=area doesn't draw
boundary
trac at osgeo.org
Fri May 16 11:37:52 EDT 2008
#171: d.vect: -c type=area doesn't draw boundary
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: d.vect |
'd.vect -c type=area' doesn't draw boundaries.
If you use type=area,boundary you get them, but IIUC "area" is an alias
for "centroid,boundary", so you shouldn't have to do that.
I am not sure if 'd.vect -a type=area' will or not.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/171>
